Reg: Model Check Batch Mode in windows
suganthan.mech
Hello Buddies
Good Day!!
Hope every one doing fine. I am using Pro/E Wildfire 3.0. I have succesfuly configured model check in interactive mode.
I am about to run a Modelcheck on some thousands of files. Going through on ptc help and the good article from ProfilesMagazin i decided to run modelcheck in batch mode. I use windows platform.
So that i have created a list of files using the
dir *.prt.* *.asm.* *.drw.* /b > list.lst
Then searched to the installation directory /bin. From there i have run modelcheck.bat. Modelcheck window appeared and i choosed "Batch mode" and browsed for the previously created list.lst file. Nothing happened.
It seems I did not get any model check out put report in my current directory. I am not sure Where I did mistake.
Kindly go through my attachment and help me to slove this issue
Any help will be appreciated.
Suganthan Rajamanickam
Pro-e System Analyst
Trane Design Centre, India
Ingersoll Rand
This email contained a .zip file attachment. Raytheon does not allow email attachments that are considered likely to contain malicious code. For your protection this attachment has been removed.
If this email is from an unknown source, please simply delete this email.
If this email was expected, and it is from a known sender, you may follow the below suggested instructions to obtain these types of attachments.
+ Instruct the sender to enclose the file(s) in a ".zip" compressed file, and rename the ".zip" compressed file with a different extension, such as, ".rtnzip". Password protecting the renamed ".zip" compressed file adds an additional layer of protection. When you receive the file, please rename it with the extension ".zip".
Additional instructions and options on how to receive these attachments can be found at:
Pro-e System Analyst Trane Design Centre, India
Ingersoll Rand
-----End...
Ingersoll Rand
-----End...
Ingersoll Rand
-----End...
Ingersoll Rand
-----End...
