Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I hope some one can help me please, I am trying to create a rendered image of our machine on a tiled floor, how do you get the image of a tiled floor to look right when you expand the room out.
ie I have an image of a tiled floor which I assign to the floor but when I expand the walls out so as I only have a floor showing the image scales with the floor thus making the tiles look wrong / over size!!
am I missing something simple?
cheers in advance
Colin Down Mechanical Design Engineer Email: - Tel: +44 1305 208503
The information in this e-mail and any attachments transmitted with it are provided in commercial confidence for the intended recipient(s). If you have received this e-mail in error, please notify the Postmaster by e-mail at -. Any views or opinions expressed are solely those of the author and do not necessarily represent those of DEK.
For local company specific legal information for your country or region and any local contact information for DEK, please refer to:
