I want to be able to leave rows in a repeat region table in the same order even if the number is changed. We are changing the key number index to a 9900 number to filter out non serviceable parts to an Arbortext xml output. The problem is that when we change the number to a 9900 number it auto sorts the number to the bottom or the table, thus removing our product structure hierarchy. Is there a way to prevent the table from reordering the key numbers after they are changed?
