Repeat Relation Relation to skip over parameters that don't exist
Chris3
One of my vendors puts their part number in a parameter called BOMINFO. I am trying to write a relation that uses that parameter for the BOM Number in the case that the parameter exists. The parameter only exists in files that I have received from this supplier. Otherwise, my BOM Number is just my Pro/E file name. The vendor has periods in their part number so I can't name the Pro/E file with their BOM Number.
The problem I am running into is that whenever the parameter does not exist in a component I get a blank value for my BOM number (I am assuming it's a NULL). Below is my relation in which I tried to test whether or not the parameter exists, but this still leaves me with a NULL value for parts that don't have the parameter.
if asm_mbr_bominfo != "NULL"
BOM_NUM = asm_mbr_bominfo
else
BOM_NUM = asm_mbr_name
endif
Anyone have any ideas how I can check if the parameter exists without returning a NULL Value when it doesn't in other components?
Christopher Rees - Mechanical Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Rd, Danbury, CT 06810 U.S.A.
Tel: +1 203 797 5490 Fax: +1 203 797 6637
christopher.rees@utas.utc.com<">mailto:christopher.rees@utas.utc.com> www.utcaerospacesystems.com
Hi Christopher,
In your repeat-region relations add the following…
IF exists("asm_mbr_bominfo")
PARTNUM = asm_mbr_bominfo
ELSE
PARTNUM = asm_mbr_name
ENDIF
For this to work, you need to add an entry in your table that gets the value of this relation. Put the following in your repeat-region table in one of the cells.
&rpt.rel.partnum
W.C. (Bill) Bowling
Aerojet Rocketdyne
Mechanical Design (MS: FB24)
Chris3
(To:Chris3)
Awesome. This worked. Thanks so much. I missed the "exists" function.
