Repeat regions in a table
ptc-593619
For all you tablers out there,
I want to put a dimension from the model into a table in the drawing. I
have made the dimension a parameter called parameter_1. Further cells
will be reading parameter_2 etc. However when I apply the repeat region
to read a parameter via properties - model - value, I do not get the
value, I get the text. Where am I going wrong? Anyone got a step by step
on this - I'm working the help menu which may as well have been written
in Urdu for all the sense I'm getting!
Richard A. Black
Lead Design Engineer
Eaton Corporation
440 Murray Hill Road
Southern Pines
NC 28387 USA
tel: 910 695 2905
fax: 910 695 2901
www.eaton.com
As it turned out, I didn't need a repeat region at all, just entering
the parameter of the dimension e.g.d694 for each cell tied the table to
the dimensions. I did have a little problem of the dimensions
disappearing from the view but with much help from Nick Ely, I was
advised to copy the table and delete the original which "tricks" ProE
into doing what was wanted. Thanks everyone else for their input and
assistance.
Richard A. Black
Eaton Corporation
Southern Pines
NC 28387 USA
