Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hey guys.
Im going through a model for a new customer. I do an edit definition on a Hole feature and it turns out to be a revolved cut for a O-Ring Groove. Im used to the Hole features being used for..... holes. I have never seen a Hole feature used to create a revolved cut. I have another model that is doing the same thing only the sketch is a really complicated revolved cut.
My question is. Is this use of the hole feature fairly common and I just havent worked for a place that does this or am I looking at some poor modeling practices?
DaveC
On justification could be tha ability to use hole tables on drawings. Pro/E won't put revolved cuts into the table.
In Reply to Mark Peterson:
I agree with Steve that this is confusing, but would go farther and say it is a poor practice because it is confusing as I would not be looking for a hole feature for a revolved cut of an 'o' ring groove. If this is associated with a hole and its pattern than it can be pattern by reference to the hole. I would be open to hear a good reason to model this way, but nothing comes to mind to support this so far. My 2 cents.
Mark A. Peterson
Design Engineer
Varel International
You know folks...there was a time whe Pro did not have the Hole feature. Creating a "hole" by using an extrude or a revolve is not an invalid technique.
