How do you think this reflects the MCAD world?
http://www.cadalyst.com/management/just-how-3d-are-we-part-1-13713
http://www.cadalyst.com/management/just-how-3d-are-we-part-2-13748
JD Mather
Certified SolidWorks Professional
Autodesk Inventor Certified Expert
[quote="iDS!"]However I do find that defining "Totally 3D" is misleading....
2D is not going anywhere anytime soon...therefore "Totally 3D" is a far fetched category and most likely not represented correctly...[/quote]
[quote]From a response to the article, "I wonder how you define whether we are 3D or not. We model our systems, but then deliver 2D views...."[/quote]
I had to go back and re-read the article, and I have come to the conclusion the survey was so poorly done as to be useless at best and misleading at worst.
When I do 3D it is a matter of course I will also generate at least some 2D documentation, and often more than I would have generated from a strictly 2D workflow. I just assume I will have an idw or dwg or slddrw along with the ipt, iam, sldprt or sldasm.
So while I define "Totally 3D" as using the 3D modeling tool as the default initial design tool from which all other documentation will be generated. The 3D model is the single source of truth for FEA, CNC and 2D documentation as required. I am also reluctant to call anything "Totally 3D" as I don't even think that is real world under any conditions. I am searching for a definition that entails 3D processes as the defining methodology, but I might start with a paper sketch on a napkin or a digital sketch. Art-to-part. What I am not doing is laborious 3rd angle orthographic projection line-by-line, arcs, hidden, sections, dumb dimensions... ...on and on.
I wonder how much of the MCAD community is doing traditional 2D orthographic projection - nothing more than electronic extension of the drawing board techniques.
How would the "business plan" of PTC or SolidWorks be defined in relation to the MCAD world?
Do these companies expect everyone to learn AutoCAD as "learning the basics of 2D drafting?
JD Mather
