Creo Parametric 11.0.5
My organization just upgraded Creo parametric from 8.0.4 to 11.0.5
compaarison of 11 vs 8
I am not sure what I am missing, but I see (8) on both sides.
Totally mis-read what you were asking.
left side is from Creo 11 & right side is from creo 8. Arrows got smaller after update.
No settings available to control that size.
Are you asking a question or just making a statement.
I can confirm is does look like they've changed it.
My image is flipped, creo 8 vs creo+ (aka creo 12)
Any solution?
@UC_11949932 wrote:
Any solution?
there are two options:
1.] these triangles are hardcoded
2.] these triangles are hidden in png files located somewhere in Creo installation directory
Simply said ... you cannot set Creo 8.0 look in Creo 11.0.
Can't find anything in Creo 11 also. That's why thread created.
Things you can do:
1. Open a tech support case with PTC and ask them if there is a way to change it.
2. If support can't help, the you can make a Creo Parametric Idea to have PTC change it.
3. there is a config.pro option that you can "scale" all of the creo to make everything bigger... dpi_scale 125 (125 is an example, 100 - 500 are the values and will increase the sizes of everything.)
my last note ... I would say that you are dealing with irrelevant problems that cannot be solved (I am more or less sure of that).
