Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Bob Frindt Sr. Designer Parker Hannifin Corporation Parker Aerospace Gas Turbine Fuel Systems Division 9200 Tyler Boulevard Mentor, OH 44060 USA direct (440) 954-8159 cell: (216) 990-8711 fax: (440) 954-8111 - www.parker.com
"Phillips, Michael D" <-> 05/01/2009 01:42 PM
To "Robert Frindt" <-> cc
Subject RE: [proecad] - RE: &todays_date
I copied this from the Pro|E help files. To Control the Format of the Date The configuration file option todays_date_note_format controls the initial format of the date displayed in a drawing. The format for the setting is a string consisting of three portions: the year, the month, and the date. You can enter the portions in any order. The default value is %dd-%Mmm-%yy . · Year o %yy, for 97 o %yyyy, for 1997 · Month (if the month contains two digits (for example, 10),% mm, % m, or % m all produce the same result) o %Mmm, for Jan o %MMM, for JAN o %Month, for January o %MONTH, for JANUARY o %mm, for 01 o %m, for 1 o % m, for <space>1 · Date (if 2 digits are needed to represent the date, all three are the same. Therefore, "%dd %mm %yy" produces "01 01 97," and "%MMM %d %yyyy" produces "JAN 1 1997") o %dd, for 01 o %d, for 1 o % d, for <space>1. The following formats are also valid: · %dd-%Mmm-%yy (= 01-Jan-97) · %mm/%dd/%yy (= 01/01/97) · %Mmm %dd,%yyyy (= Jan 01, 1997)
