All my UDF are defined in inch, that are also tooling on my punching machine, Because some of my client work in millimeter, we draw model in inch and millimeter, and all my UDF work well in both. When I use a UDF made in inch, it scale correctly in millimeter.
Yesterday, I have created my first UDF in Creo 9.0, but this morning, I want to add my UDF in a model in Millimeter, it does not scale correctly.
But I have change the unit to inch on my model, and then the UDF work correctly.
I will continue to create my model in inch, but I will prefer work in the same unit as my client. Simpler when I have to make a revision.
I have also try to manually make the form without UDF, and it does the same thing. I use Punch Forming function.
Someone know why I have this problem with my forming?
