Can you in PE have a section/slice view or graphic of your 3d model in which you can model from or project geometry ect?
I know this freature is availible in the full version of cocreate but have not been able to find it in pe.
I am not talking about 2d drawing sections in the annotation/sheet drafting environment.
Jason
I found out this is called the clipping plane.
I also learned that you can orient a work plane on a clipping plane so you do geometry edits.
Jason
