Hi There, I am trying to achieve a particular value for the Mass X distance of COFG from the rotational axis of a spinning ring with an out of balance weight by varying a single dimension on the attached part. I have created a simple relation & parameter using the calculated Mass parameter times the COFG Y called MR (on attached screen shot) . On sensitivity analysis i cannot pick up this simple calculated parameter. Any ideas why?
