Session id
JWayman
Session id
Good morning,
I know that I can find the session id of a component in the Relations window.
What I don't know is, if I know the session id, how do I find the component it refers to?
Say I click on a note that includes a parameter, and I see that it reads
'NUMBER OF WIDGETS = &NO_OF_WIDGETS:220'
How do I find out which component has session id 220?
Random stabbing is the best I can come up with so far, but that is no good if the component is a sub-assembly.
Any ideas?
John
John Wayman, C.Eng, FIED
Senior Mechanical Engineer
9 REPLIES 9
dgschaefer
(To:JWayman)
Add some text to the note that would grab a parameter with identifying information.
&partno:220
&descrition:220
I think you could even use a system parameter like &model_name:220.
I once created a table that had lines for something like 50 or 100 session IDs so I could display the PART_NAME parameter for each and figure out what part was what.  I used it for making manual BOM tables way back when Pro/Report for generating repeat region BOM tables was a separate license that we didn't have.
LinkedIn
BenLoosli
(To:JWayman)
In the Model Tree, turn on the ID field.
Thank you,
Ben H. Loosli
USEC, INC.
dgschaefer
(To:JWayman)
I think that's only feature ID, I don't think session ID can be displayed in the model tree.
LinkedIn
Add the attached note to the drawing to find session ids.
Perfect trick, thanks a lot!
jconaway
(To:MarkHeinze)
Coming in late here but THANK YOU!!!  This is such a simple solution that has evaded me for years!
this is a really good trick to get all SessionID's of an assembly quickly and at a glance.
Thank you, it saves a lot of clicks and time.
That is a SLICK trick right there!
I’ve done this a number of different ways like previous posts, but that’s
pretty dog-gone simple, at the end of the day…
dhermosillo
(To:JWayman)
I just learned this:
Tools > Relations > Show > Session ID
Pick the model and Creo reports the session ID in the messages.
Also, you can add the session ID column to the model tree as of Creo 9.
