Set Datum Display/Attachment (solution)
mwimberly
This is the solution that I have used to get what I wanted. It is a good work around because it is basically what we are doing by putting them "in" the dimension.
THE gtol is placed as a free note and then Edit > grouped to the dimension
the datum can then be placed in the GTOL
[cid:image009.jpg@01CCF233.DFFEE6A0] [cid:image010.jpg@01CCF233.DFFEE6A0]
Michael Wimberly
System Administrator, Sr
Intelligence & Security
T 513 881-4843 | M 513 833-3565 | F 513 881-5087 | -<">mailto:->
www.baesystems.com
joe_c
(To:mwimberly)
Michael
I ran into the same problem placing datum on a dimension. I tried gtol_datums to std_asme and flipping witness line and nothing changes. The triangle is behind the box fromwhat i see. please let me know what else
