Hi everyone,
I'm facing an issue regarding an expectation from designers of my team.
They would like to set a range for flexible dimension.
For instance, I insert a spring in my assembly. I set it as a flexible component, thus the spring's length changes according the assembly position.
In the case of a lenght higher than the maximum theorical spring lenght, I would get a regeneration error or an error message ....
Does anyone has an idea ?..
Yes, it's actually not that hard. This particular one limits the part to between 96 and 108.
/* DIMENSION NAMED LENGTH
length=D44
/* generate error message
LENGTH >= 96
LENGTH <= 108
/* makes overall length dimension back to max for this dash number
IF D44 < 96
D44 = 96
endif
IF D44 > 108
D44 = 108
ENDIF
length=D44
LENGTH >= 96
LENGTH <= 108
IF D44 < 96
D44 = 96
endif
IF D44 > 108
D44 = 108
ENDIF
I was not sure that the flexible dimension could be used as flexible when this one is used in the relation. Actually it works.
Thank you !
