Hi all,
I'm working on a parameter menu, which includes an real number parameter.
How do I set the parameter value of a real number parameter? I can't find it in the VB manual.
My current code:
Dim session As pfcls.IpfcBaseSession = conn.Session
Dim mdl As pfcls.IpfcModel
Dim parameter As pfcls.IpfcParameter
Dim pvalue As pfcls.IpfcParamValue
mdl = session.CurrentModel
parameter = mdl.GetParam("MP_DENSITY")
pvalue = (New CMpfcModelItem).CreateStringParamValue(CB_DENSITY.Text)
CType(parameter, pfcls.IpfcBaseParameter).Value = pvalue
I believe the red marked part needs to be changed, but no idea what should be used instead.
Thanks in advance!
try CMpfcModelItem.CreateDoubleParamValue()
