Shaft-lever mechanism problem
ptc-6420285
I'm designing an assembly which has a mechanism where a shaft turns a lever. However, I have been having a problem that the lever is not turning in the same ratio as the shaft when I drag it with the "Drag components" tool. For example, when I rotate the shaft 90 degrees the lever turns only 15 degrees. The shaft is constrained to the lever with "Coincident".
Can someone help me with this please?
0 REPLIES 0
