Sheet metal opposing bends feature creation
- December 6, 2016
- 3 replies
- 7173 views
Hi
I've created a sheet metal feature which has bends going in opposing directions from each other, see the attached image. The feature is essentially a rip across a bend with the corners of each bend folding at 90 degrees in opposite directions. When I try to flatten this part it gives an error.
I have tried creating this in two ways:
- By adding a flange and then joining the open end using the join tool.
- Making a form tool and punching the one shape into the other.
Both methods worked to create the feature but neither method works when I try to flatten the part.
What would be the best way to create this feature in order to create a flattened state?
Regards
David
