Show/Erase function
vloos
Show/Erase function
Right now our Pro-e default for show/erase is 'sel to remove'.
Where do I find the config setting for 'Show/Erase' 'Sel to keep', and
where is this placed; in the config.pro or the drawing .dtl?
I know it's somewhere we did this at my last company and now I cannot
find it.
Thanks in advance
Vinson A. Loos
Mechanical Engineering
DRS Tactical Systems - Melbourne, FL
(321) 727-3672 Ext. 3409
- <">mailto:->
www.drs.com <">http://www.drs.com>
NOTICE: This e-mail transmission (and/or the attachments accompanying it) may contain confidential or proprietary information belonging to DRS Technologies or the sender. The information is only for the use of the intended recipient. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or the taking of any action in reliance on the contents of this information is strictly prohibited. Any unauthorized interception of this transmission is illegal under the law. If you have received this transmission in error, please promptly notify the sender by reply e-mail, and then destroy all copies of the transmission.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior written approval from the U.S. Department of State."
vloos
(To:vloos)
The solution is:
show_preview_default keep
in the config.pro
Vinson A. Loos
www.drs.com
