Simplefy imported models, while keeping details
Staron
If I get a stp assembly from a supplier, what is the best way to make it into 1 part, while keeping it’s level of detail?
dschenken
(To:Staron)
Re: Simplify a Assembly into a part
The problem with importing step file assemblies as parts is Creo will simply "pile" all the different parts on top of each other (based on the coordinate system).  To fix this, set intf3d_in_as_part to yes in your config.pro file before attempting to import the file.  Now assemblies can be brought in as single parts but still maintain the proper spatial relationships between the different components. by Tom Uminn
Inoram
(To:Staron)
shrinkwrap
