Solid import from Inventor
JonathanHodgson
Pro/Gurus,
Please help - I'm tearing hair out here!
We've got a client who's sending us gearbox casing files (which we will
be modifying) from Inventor.
We've tried IGES, STEP (214) and now ACIS/SAT, but the casings
consistently import with missing surfaces (some small, some large)
and/or free edges around small fillet surfaces. Either way, I haven't
yet got a version that I can solidify.
Does anyone know of a better route from Inventor?
Alternatively, can someone point me to a guide to the WF4 version of
Import Data Doctor? I'm sure there used to be a simple method where you
set a maximum gap size and then hit "Fix" - no more, it seems...
(another PTC "improvement" 😞 )
Thanks in advance!
Jonathan
WF4 M060 (+ Windchill PDMLink 9.1 M030, for this project)
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system.Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient).Only Directors are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and other telecommunications systems.
By replying to this e-mail you give consent to such monitoring.The recipient should check e-mail and any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail. "Ricardo" means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
All,
Several replies, so thank you to everyone who took the time.
- A couple of links (and some files) to IDD tutorials, and I've now made
some sense of it (but it's *really* not intuitive now, particularly with
gaps!). I didn't completely fix the import with IDD, but I used it to
edit out some bad surfaces.
- Several suggestions concerning accuracy, and that was the final step
in getting it to work.
- A suggestion to try Parasolid. I'll keep that one in mind, and maybe
suggest it to our client for any further models.
My working solution was to take imports from both IGS and ACIS (the IGS
had fewer missing or broken surfaces, but the ACIS had different ones);
delete surfaces around the gap I couldn't fix using IDD; then copy those
surfaces from the ACIS import using a copy geom. Finally, altering the
accuracy (already absolute) persuaded it to solidify. It's not tidy,
but for this job it will do.
Thanks!
Jonathan
On the pro-e side make sure your 'start part' or 'start assembly' is
using absolute accuracy, and has the accuracy cranked down. ( I use
.0001 (inches) for parts about 20"x20"x10" ). Also check with the
suppler to see what their output accuracy is.
After doing this, I have had the best results with STEP. AP214 for
assemblies, and AP203 for parts. (Pro-E usually decides this option
automatically)
If in doubt about the start part accuracy, create a blank part/assembly
manually, set the accuracy manually, and then import the geometry file
using Import | Shared Data | from file... ( in part or assembly mode )
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
