Hello Pro/Gurus,
I've got a part of hemisphrical type. You cancosider it a part of a ball which has been cut atit's center or at an offset from the center line.This is basically a dome roof of Storage Tank for storing oil/fluid products for petrochemical industry. I've to develop flat pattern of this part for fabrication shop. As far as I know, Pro/Sheetmetal doesn't have the capability to develop non-ruled surfaces or double curvature surfaces. Is it true? If not, then please suggest me a solution, as I'm really stuck with this issue. & if yes, then can you please suggest me some other software or some workaround in Pro/E to slove this issue. I'd prefer ifI could get a solution in Pro/E. I can send theimage file if you peopleneed to understand the issue.
Looking forward to your responses. I'll post a summary for the interest of others.
TIA,
John Smith.
Design Engineer.
Pro/E does however have the capability to unbend non-ruled geometry, but it involves telling Pro/E where to allow the material to stretch, and in what manner. When you allow the stretching, it actually adds material to the model, and maybe not exactly the way you want it to, so again it increases in mass, but it does get you to the flat state. Personally, I’m not a big fan of this technique, but it is available.
Best Regards,
Matt
