Spline in Parametric 3.0
o1your
I'm working on some project and I'm using CREO parametric 3.0. I'm having a problem to identify the spline method implemented in Parametric 3.0. Which type of spline equation used in CREO? Is it NURBS or B-Spline curved equation or other type of spline curves?. Does anyone know or perhaps give me the link to answer this question?
thank you in advance.
regards.
dschenken
(To:o1your)
Google is your friend:
https://community.ptc.com/t5/PTC-Mathcad-Questions/ProE-Spline-Equation/td-p/279104/page/2
It's possible you won't need to know this if you share the reason for wanting to know. Some other method may be easier.
2 REPLIES 2
dschenken
(To:o1your)
o1your
(To:dschenken)
thank you for the reply dschenken.
the reason I want to know the type of spline because i want to make a Spline feature in Creo as my reference and it required to know the basic equation of the feature.
thank you once again.
