All,
I've noticed that when I use the hole feature, when I use an edge or a datum plane as an offset reference, the value shows 2 decimal places. However, if I use a surface as an offset reference, the value reduces to 0 decimal places. If I finish the feature and do an Edit, I can change it back tohowever many decimal placesI want. If I do an Edit Definition, I get the same behavior as when the part was originally created...
I have set the following config options:
default_dec_places 2
default_dim_num_changes no
Has anyone else seen this behavior? Is it a bug or is there a config option that I'm missing somewhere?
I'm using Creo Elements/Pro 5.0 M110.
Thanks, Roger
