Summary: Boundary Blend Suggestions
akelly
Solved.
I extruded a surface, then used the Trim command to use the existing
curves to cut off the corners. I was then able to merge this into the
existing quilt.
See attached picture for the resulting surface (before merging).
Thanks, Rui.
<<boundary blend=" solution.png=">>
rrich
2-Explorer
(To:akelly)
Ah yet another way.
Ron Rich
bgruman
(To:akelly)
exactly...
I was just looking at the picture and thinking through the number of
possibilities, order of clicks, and wondering how I could possibly answer
the question in a helpful way without writing a book!
Sometimes a simple extrude works best! 😉
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
