I had many people give me advice. The problem was spaces in the
directory that the setup files were copied to not where they were being
installed. It had that but I didn't realize that the spaces in the
setup directory was an issue.
Also I am disappointed to hear that PV Standard is going away and being
replaced with PV Pro. Unless I am mistaken, but I tried to install the
9.1 version of PV Pro, it will require a license to run which means
another license server, client links to them and not being able to run
it without the link. We are currently using Standard and using it for
design reviews not connected to the network. We there be "borrowing"
options for this too like ProE. This seems like more work than
necessary. And we are loosing the Animation portion too. Is that going
to be an add on or is it just going away?
Michael Wimberly
Engineering Applications Support Specialist II
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 881-5087 Fax
(513) 881-9800 Main
P Before printing, think about the environment.
