Sweep/Blend Feature: Hide/Unhide
TomD.inPDX
Just to let you know I added an idea that needs a few votes if you can.
I realized the other day that you cannot hide swept features or blend features (of any kind) using the now familiar hide/unhide command.
Swept/blended features can be a used as easily as Extrude or Revolve features and therefore, if they were created "independent", you should be able to hide them.
From the parts I created, I didn't see this option.
IDEA
For those not able to access IDEAS...
I see the logic for not allowing hiding swept and blended features but a test of whether or not they are "independent" would allow these to be viewed similar to Extrude and Revolve features.
There is no reason to believe sweep/blend features are -only- used to augment existing geometry.
A core functionality is being overlooked without this capability.
0 REPLIES 0
