How can I effectively link model parameters to my system parameters on templates/formats that I create? I need the model parameters to transfer to my drawing template on my BOM and Title Block, and I cannot figure out how to successfully link the two so that whenever I do need to create a drawing and I insert a part onto that template, all the information is there.
Hi Kenan,
I will give you a exemple how to do it with a parameter created by you, but remember that Creo or pro/e has some internal parameters that you can use.
1º Create a parameter on your part named "123" and give him a value number or string etc.
2º In your drawing template create a note with this &123 .
The "&" symbol is to call a part parameter.
If you have more doubts just ask.
Hugo
Hi Kenan,
Hugo
Hugo,
Thank you! It worked, and makes perfect sense. I have one more question. How can I create a standard parameter list so that each time I create a part, that same list comes up? As of now, every time I design a part, the parameter list resets. I don't want to be wasting my time every time I design a part just in rewriting the parameters. Any help would be fantastic!
Kenan,
You can create a part template with all parameters that you want. Everytime you start a new part you choose from your template. You can create parameters, planes, coordinate systems...all that you want. Since you are starting a new part those parameters are empty but they are already there.
I hope this answer your question or i am not understanding your issue now.
Hugo
How do I create a part template, then? I am currently creating a C_SIZE drawing template, so I understand how to create a template that way...would it be similar to that? I've tried creating parameters in my drawing templates, but to no avail. Maybe I am missing something?
Kenan,
A Template part part is a common part that you use to start, i will send you a exemple of a template part and a 3d format.
Hugo
*I have in there many relations that i use , u can erase all relation to test the parameters or else some parameters won't work.
Hugo,
Thanks again for your time. I will respond if I have any more questions.
Kenan
Hugo,
I am creating a "weight" column in my table, and I need to directly link the weight of the part to the table. However, I am unsure of how to link the mass properties of the part to the table in the drawing template. So...if I chose 6061 (aluminum) as my material, then the weight would automatically be changed based on the part drawn and then set in the drawing template. I hope this makes sense.
Kenan
Kenan,
1º-In your parameters add a weight parameter and make him a real number.
2º-In your relations add this relation weight=mp_mass("")
3º-In your config.pro add this line mass_property_calculate automatic
4º-In your format add a value &weight
Hugo
Hi Kenan
There is another option for showing weight in drawing
Directly use &pro_mp_mass in drawing format table(title block table)
You can reduce decimal places by using &pro_mp_mass[.3]
Regards
K.Mahanta
Hi Kshetrabasi,
I have tested that parameter (pro_mp_mass) but i think only work in certain aplications and not in Creo base, not sure yet.
Hugo
Awesome! Can I do something similar to this as well for the material from the model properties as well? So...if I want 6061 to come up on my drawing, it would appear after I have chosen the material for the part. Thanks again for the help!
Hi
Sorry for the delay
When you choose material from model properties; PTC create a system parameter PTC_MATERIAL_NAME
(check the parameters of the part)
You can use this system parameter in drawing
eg- &PTC_MATERIAL_NAME
If you want something else please reply
Regards
K.Mahanta
guys, new to CREO here, where can i find a list of default parameters like "&pro_mp_mass". it was much eesier to find back in WF.
thank you
Carlos
There is some information in the help files, and there is a drop-down in the lower right corner of the Parameters window that you can switch to show reported and alternate mass property parameters
