TR: batchs
gbon
TR: batchs
I used to use Spekan batch (3.2) for making some boring tasks on all files
stored in a directory.
For example, add some parameters in all parts, making Pdf files, printing...
Since Creo2, I can't setup this software anymore.
Is there any software that could help to program tasks in batch mode?
However, are there any freeware like Spekan purge that help to purge
directories but can keep more than one file for each model ?
Give Distributed Pro/Batch and Batch Model Check a try. With distributed pro/batch and a couple of map keys you should be able to do what you want. It's included on the installation disk for creo 2. Hope this helps, Don Anderson
