The reflect of my drawing are wrong
PH_9654403
Hello everybody,
When I reflect my drawings to another side it is not correct.
it reflects always to the wrong side. How can I choose the side I want to reflect it to?
Please help me. Thank you.
You can see on my attached file what I mean.
Patrick
Chris3
(To:PH_9654403)
I think you are asking about first angle projection. Open the drawing detail options by typing "detail options" into the search (its not in the default ribbon):
Search for projection_type and change the value from the default of THIRD_ANGLE to FIRST_ANGLE
StephenW
(To:PH_9654403)
I don't understand your use of the term "reflection". Are you trying to mirror your part to make a right-hand/left-hand part?
Or are you referring to creating views that are projecting incorrectly?
Maybe you are wanting first angle projection and the software is defaulting to third angle projection?
I see your PDF, but don't understand the question.
Chris3
(To:PH_9654403)
PH_9654403
(To:Chris3)
Thank you. I was looking for this. Sorry for explaining my issue so bad
