Tool BOM with bulk parts
VW_13931977
3-Newcomer
Hi All!
I am trying to open an existing solid tool (assembly) with bulk parts for the inserts and screws (I don't want to model them separately) in the NC assembly environment , My problem is, that Creo doesn't recognize the proper quantity even though the BOM_REPORT_QUANTITY parameter is already set.
Also, can I use a parameter to override the type field to show INSERT / HOLDER instead of GENERIC?
Is there any workaround for this? Thank you!
I am using Creo 12.
Hi @VW_13931977,
Thank you for your question.
 Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
Thank you!
Unfortunately it seems, there is no solution 😥
Lets hope Creo 13 will fix this issue! 😁
Viktor
