I am trying to get Pro/E WF2 to show me a summary of the total mass of all the parts in an assembly, and it is misbehaving.
I have set up a custom bom format file:
.breakdown
%$type %$name contains the following:
.titles Qty; Name; Material; Mass
.row %$quantity[-4d];%$name[-15.12s];%material[-10.7s];;%pro_mp_mass[-5.2f]
.summary
Listing of parts for assembly %$name:
.titles Qty; Name; Mass
.row %$quantity[-6d];%$name[-15.12s];%pro_mp_mass[-5.2f]
TOTAL MASS: $%[$total(pro_mp_mass)][-5.2f]
I have also set up a nested repeat region on a GA drawing, with a summation of the column containing the mass of everything in the outer (top level) region.
I have also set up my model tree to show a mass column.
Following regeneration:
The Model Tree reports the total mass as 3124kg
The Repeat Region reports the mass as 2719kg
The Custom BOM reports the mass as 3106kg
All three are working on the Master Rep
How is this possible?
The trouble is, I now do not know which to trust, if any.
My money tends to be on the model tree, but who knows?
I would welcome any constructive suggestions on how to make the three figures converge.
John
hi John,
Maybe some of these ways to report mass of an assembly behave like ModelCheck on measuring the 3 overall dimensons of a model.
It could be that it counts in burried features in some cases and and maybe even holes and cuts as they are filled.
You would need to go into a detail there and do you own measurements on simple and compound models if you want to make sure what's going on there.
I would try to compare this with other cad system on the same models.
~Jakub
