Trouble when using a parameter in a repeat region relation
jlecointre
Hello all,
I have a problem with a parameter created in an assembly that I cannot use in the relations of a repeat region in the related drawing.
The value of this parameter cannot be displayed in the repeat region nor used in a relation (that causes the variable using this parameter in the relation replaced by a blank in the corresponding cell of the repeat region).
Nevertheless, I can display the value of this parameter in a separate note.More to say, I also have other relations using other parameters that works properly.
I tried to create another parameter with a new name, butwith no success. This parameter takes its value from a relation using another parameter coming from a part, but cancelling this relation and attributing directly the value manually doesn't help.
I'm using Pro/E WF4.
Help much appreciated.
Kind regards.
0 REPLIES 0
