I am unable to open the user interface of cosmetic thread. Whenever I click on the cosmetic thread tab
it takes me to some intudfs folder having two folders inside (External and Internal) containing .gph files.
I'm not sure if it is some kind of bug or do I have to modify some parameter in config.
Any help would be greatly appreciated.
Thanks.
You may check the option in config.pro and config.sup on your machine.
Thanks.
Hi @ZGhumman
Set config option allow_udf_style_cosm_threads as no (default). I hope that will help.
It's already set as default (i.e. No).
The Asterisk next to no means that no is default, it does not mean your setting is no.
If you don't have a line in your config(s) that specifically changes it to yes, then it is by default no.
You HAVE to look at the lines in your config files to verify.
I don't have that option set, but as an example, on my config
Allow_freeze_failed_assy_comp YES (no asterisk mean it is not set to default, ie I have changed the option from default)
Allow_red_interstection NO* (asterisk means the setting is the default setting AND I have it specified in one of my config.pro files explicitly as NO)
All I am saying is using "find" won't necessarily tell you what you have it set to
Thanks for the explanation, I didn't know that..
but that parameter, "allow_udf_style_cosm_threads" is already set as "No" in the config.
