Unable to use "edit definition" on notes
KF_7767247
3-Newcomer
I am using Creo Parametric 7.0 7.0.2.0
I am unable to use "edit definition" on notes both in my drawing and my model. I can only edit the note when it's physically placed in the model and I have to manually type everything in a text box rather than using the standardized note files my organization provides. There is a small clock icon that appears next to the affected notes.
please publish pictures showing your model/drawing. If you can please upload data to enable community users to reproduce your problem.
Martin Hanák
Hi @KF_7767247,
If you are looking forward to insert *.txt files in the Notes, then please make use of the option Note from File.
Below mentioned is a demonstration of the same:
Let me know if this helps.
Again, if I am wrong with my understanding, please help us with some snapshots or data that will clarify the issue.
Looking forward to hearing from you.
Deepak
