Hi to everybody,
i have good skills with round tool, but i never used attached options.
Someone can post some examples about that?
Thank you. I ever had a great solutions in this community.
Extend surfaces and full round.
Extend surfaces is a diffrent way to evaluate the rounds.
Look this up in your help files:
Example: Extended Surface Rounds
Full round is great for many applications. It simply uses an additional surface to determine the radius. Full rounds also helps define a variable radius when you might want to control the height or depth of the round.
