Upcounting number for symbol in Creo Parametric
ML_10821525
3-Newcomer
Hello everyone
I am using Creo Parametric 9. I'd like to create a symbol in which i can insert an upcounting number tepends on how many of this symbols are in the model. Eg. If there are 3 symbols in the model and i insert an other one the number of the inserted symbol schould be 4. The other symbols shouldnt update the number.
Thanks for help.
@ML_10821525 wrote:
Hello everyone
Thanks for help.
drawing symbol can contain variable text. Unfortunately you have to enter value manually.
Martin Hanák
BenLoosli
(To:ML_10821525)
If you can write some code, you may be able to put the number of symbols in a parameter and then build a table that references the parameter so it updates.
BG_9869104
(To:ML_10821525)
No. Not built in. 3rd party tools only.
Can build janky mapkey+relation counter but it's not production viable in my opinion.
