Use simp reps from sub-assemblies in main-assembly
mhergenhan
2-Explorer
Is it possible to reuse simplified representations or style states from a sub assembly inside the main assembly? Without creating it again in the main assembly...
TomU
(To:mhergenhan)
Sort of. You create a new simplified rep in the upper level assembly and then choose the sub-assembly's already created simplified rep to reuse.
5 REPLIES 5
TomU
(To:mhergenhan)
TomU
(To:mhergenhan)
Here's a screenshot:
mhergenhan
2-Explorer
(To:TomU)
Hi Tom,
many thanks!
I got it.
Is this also possible for style states?
TomU
(To:mhergenhan)
Yes, just slightly different. Create the sub-assembly style state. Then, create a new style state in the upper level assembly. Go to the "By Display" tab, select the sub-assembly from the model tree, then select the style state you want to use.
mhergenhan
2-Explorer
(To:TomU)
Great! I got it. Many thanks
