User-defined parameters as notes in drawing
meline
2-Explorer
I've populated my family table with user defined parametes whose values may vary depending on which instance of the model is selected. These parameters are not critical to the part geometry but is data that is associated with the components that I'd like to show as notes in the assembly drawing. I know how to use session id's to show component data but I can't seem to return the user defined data that is not directly related to part geometry data....any thoughts?
Thanks in advance!
0 REPLIES 0
