Using Off the Shelf Cables in Multiple Assemblies
dwilliams
Since Pro/Cable requires a new assembly for every route, how does one
re-use off the shelf cables in different Pro/E assemblies? Ideally, you
should be able to re-use an off the shelf cable using the vendor number
and route it as necessary in any assembly. Unfortunately, it doesn't
work that way.
Any strategies to overcome this?
Thank you for your advice,
Dax Williams
Engineering E-Tools Administrator
GE Healthcare OEC
Surgery
384 Wright Brothers Dr
Salt Lake City, Utah 84116
0 REPLIES 0
