Using Part meshes in an Assembly
Dear readers,
I am struggling with the integrated pro/Mechanica Wilfire 4 interface, because I want to run a modal analysis from an assembly with a fine mesh.
I created the meshes in the individual parts (but added some masses and beams in the assembly). The assembly does run and gives results but it created new very large elements which i don't like. Is there a possibility to enforce Mechanica to use the meshes created in the parts?
Hanjo
