Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Back when we upgraded to WF2,we found that the PRO_MP_VOLUME parameter eliminated the need for any relations; however, the Generate Report button in the Edit~Setup~Mass Props dialog box needed to be selected in order to sync the value you see on the drawing versus the value you would see from doing a model mass props via the Model Analysis. Not a particularly obvious solution to the problem. Regardless,
Our solution was to edit the Pro/Program in the start part (and edit exisiting parts as the opportunity presents itself) and include a line between MASSPROP and END MASSPROP at the end of the Pro/Program, for example if the part # is xyz it would be:
MASSPROP
PART xyz (Can be done w/ assemblies syntax is ASSEMBLY xyz)
END MASSPROP
The "xyz" updates fine with renames and save a copy.
We do not use the config option mentioned by Brandon for the same reasons he stated.
<u>Now, the drawback to the method I mentioned is that the UNDO functionality istoast after you regenerate (doesn't affect intent manager UNDO).</u>
Just use the &pro_mp_volume[.x] (x being the sig digits) in a note or in a format cell to report the value.
Other than the UNDO issue, it works fine.
In Reply to John Scranton:
We are having a problem getting the volume note on a drawing to update with the changes to the part model.
The process we have followed is as follows:
1. Calculate the mass properties for the part
2. Create a string parameter called VOLUME
3. Write a relation: VOLUME = MP_VOLUME(" ")
4. Create a note on the drawing: volume = &volume IN@+3@#
This is reporting a value but it is incorrect as compared to the model
We are using WF2.0
Can someone offer a solution please?
John M. Scranton
Senior Designer
Ultra USSI
4578 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Voice: 260.248.3576
*Fax; 260.248.3509
[cid:image001.jpg@01CA5883.522D21D0]
