View name for drawing note.
sachinnet
Is it possible to get view name for drawing note which is attached to one of the view? Please suggest procedure or API to get view name info from note object.
TIA
-Sachin
pwilliams-3
(To:sachinnet)
Sachin,
Read the API Wizard under User's Guide->Drawings->Detail Items. There you
will find all of the APIs that are used to create detail entities (notes).
If I wanted to find the view to which a note was attached I would use the
following procedure:
Collect the drawing notes ProDrawingDtlnotesCollect().
Iterate through each drawing note with a for loop.
Get the note data ProDtlnoteDataGet()
Get the note data attachment ProDtlnotedataAttachmentGet().
Get all of the attachment data ProDtlattachGet(). Determine the
attachment type. Only the PRO_DTLATTACHTYPE_FREE attachment type will
have a reference to a drawing view. If the attachment type is correct
then the 'view' output argument will be valid.
Get the name of the view ProDrawingViewNameGet().
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
