Why back in the day did every seq have a next seq buttton and now we have squat ?
And also we need the same thing in Custom Traj. Build box.
So we start new Traj milling standard site file then we start building tool pathes change 5 parameters for the cut pick chains then levels then next cut pick new chain and continue levels parameters stay until changed. Not start all over that is ridiculous.
It use to be so efficient not so much anymore.
Why has no one else complained about this?
Maryland Machine
you could do a copy/paste... ? I know the right-click menu does not say 'Copy' , 'Paste', but you can do it with Ctrl+c / Ctrl+v
then you just have to re-pick the chain and voila
CTL C,V does work in main tree but not the build box. And in addtion is several extra steps (clicks) away then the actual next seq. or next cut (inside buildbox) would be.
I do this every day 10-12 hours a day it gets incredibly redundent not have theses simple tools at our finger tips.
MM
Brent,
The copy and paste in process manager works very well. Try it there, I use it all the time for repetitive features in manufacturing
