aXIS dISPLAY WF4
bbenitez
aXIS dISPLAY WF4
Hello All
I am doing a little project in WF4 - today is my first time using WF4.
In Drawing mode I "show" the AXIS in a cylindrical part and the Axis Tag
(i.e. A1, A27) shows up.
In WF2 we don't have the problem of the tag showing along with the Axis by
default - but it does in this fresh load of WF4 and I can't find the option
to get it turned off.
Since I need to get this done - any help with as to where the switch is
located would be appreciated.
Remember - I want the axis to show, just not the tag.
Thanks in advance
Anthony
Turn off your global axis display and the tag will go away.
Alternatively, create a layer and place all the axes on that layer and
unhide the layer in the drawing and save the layer status.
As far as I know, this has been the way things have worked with drawings
in Pro/E back as far as I've been using Pro/E (1996, Rev16).
Doug Schaefer
LinkedIn
RandyJones
20-Turquoise
(To:bbenitez)
On 01/25/12 16:40, Anthony Benitez wrote:
> Hello All
> I am doing a little project in WF4 -- today is my first time using WF4.
> In Drawing mode I "show" the AXIS in a cylindrical part and the Axis Tag  (i.e. A1, A27) shows up.
> In WF2 we don't have the problem of the tag showing along with the Axis by default -- but it does
> in this fresh load of WF4 and I can't find the option to get it turned off.
Try this:
File | Properties | Drawing Options
enter "update_drawing" as the option and "all" as the value
Add/Change | OK | Done/Return
View | Update | All Sheets
> Since I need to get this done -- any help with as to where the switch is located would be appreciated.
> Remember -- I want the axis to show, just not the tag.
> Thanks in advance
> Anthony
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
