Does anyone know how turn on and off the boundaries in a partial view (CREO 2.0 Parametric)?
Double click on the partial view and there is a tick box for Show spline bounday on view in the Visible Area 'tab'
It was already checked. I also tried unchecking it and nothing happened.
Hmmm, mine works so I can't really help! I am on Creo2 M040
The boundary only shows for where it cuts through a solid (or surface) and not the entire spline, if that is what you are after.
edit: As I remember, I use to sketch that circle manually to get that spyglass type of detail view.
