break the leader of the geometrical tolerance on 2D drawing
ptc-1880224
does anyone know how to treat. I want to break the leader of the geometrical tolerance that intersect with roughness symbol. Pease tell me how to operate under Proe 4.0 Thanks very much and nice day.
You can't. You can only break the leader line of a dimension, not a GD&T leader.
What kind of G-tol is it, if it's one that can be associated with a dimension, you can break the dimension leader like stated above. If it's a stand alone G-tol you should be able to move out of the way. Also if it's pointing to a surface or a line, you can use a tangent or perpendicular leaders, which will help place it.
thanks all of you!
