can you use parameters instead of part name in a hint map for creo?
mgardner
I have been working with a hint map for MCAD/ECAD collaboration and want to know if its possible to replace the MCAD_TYPE & MCAD_NAME with a parameter created or existing in the creo part instead of a part number.
example hint map:
Map_objects_by_name ->
ECAD_NAME "CONN2375X1841X782-15_PTH"
ECAD_ALT_NAME "1AB169630003"
ECAD_TYPE " "
MCAD_NAME "836129020"
MCAD_TYPE "part"
MCAD_LAYER "CONN2375X1841X782-15_PTH"
END
example of what is wanted:
ECAD_TYPE " "
MCAD_NAME "connector board to board male ..."
MCAD_TYPE "parameter = FULL_DESC"                  (where the hint map would look under the parts parameter for the description instead of the parts file name)
END
David_M
(To:mgardner)
I don't think that Creo has support for this. Do you have access to the document Pro/ECAD Help Topic Collection? If not, it is easy to find this via a quick search.
I could not find the document you are referring to.  Could you post a link?
