choose top level assembly file directly for ease of use?
Bhoopathy
Hello PTC Community,
Kindly facilitate to Choose top level assembly file directly for ease of use?
thanks
bhoopathy
dm-4
7-Bedrock
(To:Bhoopathy)
Hi Boopathy,
I do not think it is possible.
rcox
3-Newcomer
(To:Bhoopathy)
I identify the top level assembly like this: Filename-TLA.asm.
And weldments, which are parts in the physical world, but assemblies in Creo like this: Filename-WLD.asm.
Hello Bhoopathy K
the best way "How to select top level assembly" is following:
Top level assembly is named like: 00_ ...
This will guarantee, that top level assembly will be shown as one of first row.
Our PTC provider AVengineering use the same method...
Regards
Milan Bonka
psobejko
(To:Bhoopathy)
This is not possible out-of-the-box.  Just how would you have the system determine that a file is a top-level assembly?
By the way, if you don't have Windchill and access to where-used function, then this might be an alternative:
Where used?
