control decimal places of dimensions in model and drawing
AnkurAggarwal
Hi all I have a question about decimal places of dimensions in model and drawing. I want a dimension in model to be 1.5584. I want it to four decimal places because of interference issues in assembly. In the component drawing of this component, I want to show it as two decimal places that is 1.56. But if I use show/erase, then 1.5584 is displayed and I cannot modify it as it will modify part also and that will create problems in assembly. How can I show it as 1.56 instaed of 1.5584 ? Thanks Ankur
You will have to create the dimension in the drawing. No other way around having different dimensions
Thats what I was thinking of. Thanks Eric.
Depending on the circumstances, making the component dimension flexible in the assembly could be a solution. Regards-
